But is it a beep or is the the horn?
Moreover, is it possible to active both the beep and the welcome light when you open the car with keyfob? -
Hi!
Its a single "beep" ... but you need the original bmw anti-theft alarm system to get this feature. So its not the horn, its a single / double beep from the alarm system, not the normal horn
Hi!
Well! I have the mini anti theft alarm system
I'm waiting for the enet cable to do many coding I found here.
Thanks guys! I'm too happy
When you use the esys software, do you start the engine or not?
Moreover, do you connect the laptop with charger to the mains or laptop battery is enough? -
You just need ignition for this, not necessary to start your engine.
The other thing depends on your laptop & car battery ... with a new mini the battery is strong enough to code ... and you know the lifetime of your laptop using battery ;). But if the laptop crashes during coding, you're in big trouble!
I've a new macbook air and use all tools without hooking it up with a charger ... and if the battery of the car goes down you get a notification and just could start the engine to charge the cars battery :). Just when you want to flash firmware to your car its a good idea to hook laptop & car up with a charger!
My fear is that my little Asus EEE PC 101CH doesn't run correctly the esys software because it has only 1 Gb ram and a slow processor, Intel Atom. How can I test the esys software without crash the central unit of my MCS?
ps: Have I to close the antivirus?
I recommend you get a new laptop ... this netbooks are not strong enough to work without errors ... its just critical with this small power!
- Driving Modes bleiben nach Motorstart unverändert und springen nicht zwingend auf MID zurück
- Menüpunkt für akustisches Verriegelungssignal
Which are the codes for this functions? I'm not able to find in bimmerfest
Thanks a lot!ps: can I codify many functions in the same session of coding, or is it better coding in two or three session?
Hatte einen da, der meinen F56 Works codieren wollte, dieser konnte jedoch nichts Codieren, das die Software zum Codieren beim Auslesen schon einen Fehlerausgeworfen hat.
@crazyiven ich werde mich mal vertrauensvoll an Fabec wenden
Ich denke Ihn wirst du auch kennen
